I've searched the forums and haven't found mention of this particular problem yet so I wanted to see if anyone can help diagnose this problem.
In the last few days, my '77 (302 with C4) has started making an odd noise when it shifts from 1st to 2nd gear. I heard it intermittently a few weeks ago but it only did it once and then again a few days later. At the time, I wasn't sure what I was hearing. Both times I was turning a corner and I thought the sound was something sliding across the bed in the back of the truck (there are a few things loose back there; so it made sense).
I didn't hear the sound again until a couple of days ago and now it has started recurring regularly. It actually sounds like a scraping noise, not overly loud but easily heard and very short, maybe one second in length. It sounds very similar to something sliding across a floor, maybe a dresser being slid away from a wall on a hard floor; something like that.
Also, it only happens when accelerating and the truck shifts from first to second gear; and only when increasing at a slow rate. When I drive it slightly more aggressively from takeoff (normal for me), I don't hear the noise but there is a hard kick when it shifts into second. Second to third is extremely smooth; so much so that you have to listen for it or you won't even notice the shift.
Lastly, when I shift the truck manually, the noise isn't produced. And other than the noise I'm hearing the truck is driving fine. I have checked the fluid levels and they are good. Any ideas what I might be looking at here; things to check?
Thanks,
Jack
Thanks,
Jack
