My c4 doesn’t seem to have Neutral….
Ididit auto column with column shift; c4 with unknown history
Installed a Lokar rod shifter per instructions and did best I could to adjust on no-running truck. Now it’s running and N is nonexistent. I can’t locate N between R and D using the shifter so I disconnected the driveshafts from the t-case and laid under it to shift the trans manually. No N anywhere.
Why would my c4 not have N? R and D, D2 and D1 all spin as expected. N is nowhere to be found.
Adding - engine off, moved trans linkage to N. Started engine and yoke is being driven.
Any ideas?
Any ideas?
