Yes, but,
The carb needs to be for a Ford with the kick down provision on the throttle shaft.
I had to fab a short extention onto the kick down for it to work better.
I made two pieces of flat sheet metal, about one inch long and .5 tall. Drilled two holes. One hole for the kick down tube, bolted to piece. And the other hole sits on the throttle provision, fastened by a E clip and washer.
Added a very light return spring to the provision to keep the kicker pulled up.
My carb didnt have a set screw to adjust when the kick down gets pushed. Sourced that from my bucket-o-bolts.
If you need a pic I could text you one.
Took about 15 minutes to make.
