lowbush
So I got one for your guys, I took the Bronco out today for the first real test drive after getting the transmission built and I have a strange issue going on, the truck shifts fine but if I run it up to the high gear it seems like it does not want to shift out of it, when I stop and then try to go, it just crawls until it gets up to speed, now if I stop after getting up to the high gear and put it in reverse and run it backwards a little bit and then go forward again, it picks right up and I never loose power again until I feel if shift into high gear and then I have to drop it into reverse again. Does that sound like any symptoms any of you guys are familiar with? Other than that the thing ran like a champ, I put it thru some deep holes out in Holopaw and it swam right thru them.
