- Mar 8, 2007
- 81,824
Laura @ 816-241-3676, lmajerus@Transtar1.com
Transtar Industries, Inc.,
1651 N. Topping AV
Kansas City, MO 64120
1651 N. Topping AV
Tracked that seal down in California for $15.00 but if I can find one from someone more local for the same price that would be preferable.
Thanks again
Ok. Measured the case end play clearance and with the feeler gage I am showing slightly greater than the upper limit of .042 so at about .045. It looks like I will be waiting for my dial indicator to get here so I can confirm this issue. If I do end up having too much gap I have to option of obtaining different thicknesses of no.1 and no.2 thrust washers for a fix which leads me to a few questions.
1. Are the thrush washers considered a wear item in these units? If not, what component is wearing and causing this out of limits gap.
2. If the thrust washer is a wear item, should I try and get the specs for my current washers and mic them to confirm they are worn down?
3. If I go get new thrust washers, what combination should I purchase? Do they come in a matched set based on thickness or am I piece mealing this to get my own desired thickness? If piecemeal, should I go for a no.1 that is thicker than the no.2 or vice-versa?
4. What thickness washer or better yet what end play do I want to try and achieve. There is a lot of limit in here .008-.042.
a) The #2 small bronze washer is responsible for the overall unit end play, which you adjust first.
b) The #1 plastic washer adjusts the direct drum end play only and should not be used in any other fashion.
~bh~
How do I determine the direct drum endplay? Just by feel or is there a measurement I can take?
Right now my endplay is at .005 with a #1 thrust washer of .069 and a #2 of .091.
I guess I need to go find a smaller #2 to fix this issue. Maybe a .074 or .057 will be the ticket.
Thx.
