I recently acquired a '74 model with the 302 and C4 trans. I got the engine issues squared away and moved on to the transmission. Although the transmission
shifted OK, the fluid looked and smelled burnt. I dropped the pan and changed the filter, buttoned it up and replaced the ATF. That's it, didn't touch anything else.
Transmission now slips from 1st to 2nd and cold, will only shift into 3rd when (I assume) hits the governor. After that, shifts a bit early into 2nd with a momentary
slip and goes into 3rd OK. An old time mechanic friend told me that's not uncommon, sort of like the gunk was keeping the clutches working and new fluid made
everything slippery again. Changed the modulator and checked proper vacuum hose connections, no difference. My knowledge of A/T's is limited. (1) Is this something
that can be adjusted or do I need a transmission rebuild or exchange? (2) If it's the latter, can anyone recommend a shop in San Diego East county that is willing to
work on a 48 year old car's transmission?
