GloNDark
- Aug 22, 2007
- 399
Brief background on the issue. It once was intermittant, and now seems permanent. I drop the shifter into reverse, I can hear a "click" and then movement from the trans but no reverse. Appears to have 1 thru 3 gears.
I swapped out the reverse servo piston hoping the seal was bad and a new one would solve the problem, but no dice.
So I dropped the pan. There was the typical gray sludge in the bottom, but overall the internals "look" to be in ok shape. No broken bands and what not.
However apon removing the valve body and taking the 2 halfs apart I ran into some weirdness. There is a hockey puck shaped item in there, but no check balls. Yah, no check balls. ?? I'm sure this has something to do with my problem at this point.
I then moved on and did the typical air checks on the valves. Everything checked out, and appear operational with the exception of the govenor valve. It blows air straight thru, no fast FAP sound what so ever.
I'm at a loss. Any ideas?
