[quote author=Broncobowsher link=board=5;threadid=12090;start=0#89826 date=1039463251]<br>My guess is valve body. Did you do any type of shift kit?<br><br>I am guessing that you may have a tired spring in the valve body. At light throttle you get the 2-3 shift before the 1-2. It has been too long since I studied hydrolic schamatics to see if the 2-3 has to wait until the 1-2 signal, or if it will override it?<br><br>Does when it shift normally does it shift 2-3 right after the 1-2? Light throttle, normal shifts?<br><br>Trade the valve body in on a reman unit before redoing the whole tranny. Most of the odd tranny problems I have seen are valvebody related. Hard parts usually have a real serious problems.<br>[/quote]<br><br>Yeah, if I accelerate normally, like off the line, it winds up, shifts 1-2 exactly how it should and then shifts 2-3 exactly how it should. If I start out with really light throttle, it will sometimes shift to 2nd and sometimes it will shift straight to third. It is most noticeable when I am turing in a green turn arrow lane and start out in light throttle. It did it this morning. After it does this, if I jump on the throttle a little bit, it will shift back down into 2nd and then to third, just like it should.<br><br>A little history on the tranny. I rebuilt it with the help of a Ford mechanic. Put it back in and got it running, but didn't have 3rd or reverse. Thinking it might be valve body related, I got a used valve body and threw it in there. That didn't fix the problem, so I pulled the tranny back out and found they had given me the wrong sealing washers that go around the front pump hub and fit into the forward/reverse clutch assembly. Put some new rings on, and it has worked great ever since, except for this skipping second. I still have the original bronco valve body but I have hesitated to put it back in because I put a B&M street/strip shift kit in it and I should have gone with the street, not the strip version!!! It is a little bit too hard of a shift for me. Feels like it is beating up the rest of the drivetrain when it shifts. maybe i will throw it back in the tranny and see what happens. I am also going to adjust the bands again to see if theat helps. I seriously doubt that the bands or drums are jacked up since the tranny works perfectly most of the time. Doesn't slip at all.<br><br>By the way, does anyone know the correct band adjusting procedure? I don't have a book that tells me.<br><br>Thank for the ideas.
