I recently swiped out my C4 for a more modern AOD trans. It was definitely worth it. I live in southern California and the normal freeway speeds are 75-80mph. With the AOD I am now able to drive at 72-75mph while doing 2300rpm. The issue I am having is that I kept my original 74 steering column and the original automatic column shifter. With the AOD P and R and about the same on the column shift indicator, but Neutral is now between Reverse and Neutral and Drive is where Neutral is. Is there a way to adjust the indicator so all my shift points are where they should be. Or is there an AOD shift indicator that I can switch mine to?.
