C4 Transmission Problems after rebuild engine
broncorican
Caguas, Puerto Rico
I found a thread that had some problems after installing a rebuilt engine but it had to do with the shifter and linkage. I have a different problem, once you shift into drive or reverse, the vehicle will not move until you accelerate the engine for a few seconds (5-10) and then it starts to move slowly. The Bronco is a 1974, with an automatic trans that was running fine before the engine being removed, 302 engine recently rebuild with pistons cut to .40. The vehicle has sat for approximately 90 days while the job on the engine was completed. I'm not a mechanic and did not rebuild the engine, but I'm curious to know what this problem may be before taking it to transmission shop. Thanks.
mike732
Camden, Tennessee
It sounds low of fluid, get it good and warm and check that first. Did you put in a diffrent converter, a higher stall speed whould do that also...
Tenacious-B
Laguna Hills, CA
Could be that when the engine was pulled the torque converter came out and dumped a bunch of fluid. I'd check the level like mike732 said first. Post up what you find.
blazinchuck
Dont mean to hi jack, but I'm removing my C4 right now...can I leave the flywheel/torque bolts in and remove the tranny 1st. Then go back and remove the torque convertor from the fly wheel later? It's a pain trying to turn and hold the fly wheel while removing the nuts,Chuck
blazinchuck
thanks, thats just what my buddies told me, and I yanked it out earlier today.Chuck
clayne
You have probably flush trash in the Pressure regulator in the valve body. It happens alot when air get in the transmission lines. Need the valvebody cleaned.
blazinchuck
what kind of trans jacks are you guys using to pull out your C4s??
this is the one I used,got it from work;D
these work just as good,Chuck
broncorican
broncorican
Caguas, Puerto Rico
Problem continued. Mechanic sent it over to a transmission expert. Suspects the improved motor with pistons cut to .40 and high output, may have pushed the trans to it's end. We'll see what happened to the trans and let you know.
GubNi
Northeast TN
Yep, that's a common problem with older trans. If it's ok after the first time it gets moving then nothing to worry about. If it happens every time you start from a stop, then rebuild is needed.
