CA Smog
budman
COVINA, CA
This is the first time I've asked any questions here and I hope its right. I have a 1977 Bronco sport and live in southern CA. I purchased it in Utah several years ago and found a local shop that HELPED me get it smogged the first time. Its got a 351w, Holley truck avenger carb, performance ignition and Duff headers. The fuel tanks are not stock, they are after market units. There is no smog eqiupment what so ever on this thing and this year the state is requesting that I go to a Test Only Center to be tested before I can get my new registration. I dont think that any early Bronco's came with this motor and have no idea what it came out of. I'm sure that I will have to install all of the smog equipment that a 351w would have had in 1977. The shop that helped me out the first time looked it up and gave me a list of equipment, or abreviations that I think is equipment. I know what the PCV and EGR valves are, but cant find info for ACL, FR, AIS, EVAP. I would be gratefull for any info if any one has gone through something similar or has an idea of what I might need and where I can find it.
Tito
CB Fire Starter
Bakersfield, CA
Usually they cant even tell the difference between the 302 and the 351 but some of the things you might have to have on it are
EGR
PCV
Smog Pump
Cat - definitely
fuel vapor can - maybe, not sure
stock air cleaner
most of this stuff is easy to borrow or get ahold of except the cat, thats a matter of putting one back on.
From my experience this is about all you need to pass the visual, the tailpipe is a matter of detuning a bit and leaning out the carb. You should be able to get all of this taken care of to smog it, if they ask what size engine just say its a 302. The pain in the ass part is the cat if you have modified the exhaust.
73stallion
Eugene, OR
the really bad part is most people who take the smog requipment off toss it in the trash, so things like the pulleys, smog pump, pollution tubes, and air cleaners are getting difficult to find.
i do have a stock air cleaner and stove pipe if you need one. the stove pipe can be clamped to the header and pass.
72Sport
They will probably notice the carb if it is a 4 barrel. If so you will have to change intake manifolds and reinstall a 2 barrel.
There was a mobile smog check station on Grand in Covina on June 1st. If you get stopped in one of those you will have to fix everything even if you could find a shop to pass it as is.
From what I have been able to find out any vehicle from 66-75 that is "dirty" will have to be smogged also. The smog exemption is only for the biennial testing not an exemption from having smog equipment and running clean.
Galt72
it's been a few years but I remember having to swap in a 2 barrel. You will need a closed air cleaner with the heat tube from the exhaust maifold. I went to pick and pull and yanked everything off an old Granada for cheap. I also had to hook up the charcole canister to pass.
mitzel
Googleplex
If you do a bit of searching in the archives I think you can find a number
of useful old threads covering various issues with smog check equipment,
those abbreviations, other's experiences, etc. From my memory I think
those abbreviations that have you stumpped include:
ACL: Thermostatic air cleaner. As others mentioned that's the stock
air cleaner housing and the heat tube that runs down to the exhaust
manifold and has some sort of thermostatic flapper valve in it.
FR: Fuel restrictor. That's a flapper valve that goes right inside the
fuel filler neck. This prevents the larger nozzle on a leaded fuel
gas pump from fitting into the filler neck of a vehicle requiring
unleaded fuel.
AIS: Air injection system. That's the thermactor or smog pump others
have mentioned.
EVAP: Evaporative emissions. That's the charcoal canister others have
mentioned. I don't know if a smog tech would trace out the connections
but a properly plumbed system should have the small inlets plumbed to
each fuel tank and the carb fuel bowl and the large outlet connects
to the air cleaner housing to suck fumes through the carb.
One not on your list but likely required is OC: Oxidizing catalytic converter.
I think if you can get a the parts in place for a '77 302 then it's unlikely
the smog tech notice the 302 vs. 351 difference. Good luck!
72Sport
I think I would find a mid seventies Ford Granada, Mercury Monarch or v-8 Maverick or Comet at the local wrecking yard and pull off everything I needed. Some Granadas had 351's in them which would probably get everything you need except air cleaner. The Granadas etc are pretty easy to find. They are always missing the front disc brakes.
Maybe someone will post some pictures of their engine compartment so you can see what you need. My 72 doesn't require the smog pump etc so a picture of the smog stuff wouldn't help.
B
budman
COVINA, CA
Thanks to all of you who were able to give some advice, all of this info is going to be a huge help. Those of you that had parts I might be able to puschase I will contact individually when my parts collection begins. This advice will save me countless hours of phone calls and anoying the local shops for info. This is a great site and I hope members continue to contribute in the possitive ways as you all do.
Which way did the Air Pump pump on a Bronco? Did it go into the heads or the exhaust manifolds? If the heads, then all you have to do is uncork a port and attach the plumbing (assuming they're smog heads that is), but if the manifolds then you'll have to modify the headers with air tubes.
Headers are usually legal as long as they are not defeating the purpose of an existing smog device.
Most likely it wouldn't make a difference either way as long as the air pump is hooked up and functioning. The tech probably wouldn't differentiate between the two types, I'd guess.
jdkin01
SoCal
I bought my '76 Bronco in Texas, no smog equipment what so ever. The smog guy told me to go buy a old Fairmont with all the smog stuff on it. My friend found me me a '78 in the desert. Trailered it home and went to work. The Fairmont was cheaper and easier then trying to find all the parts at pick a part. Put everything together and it passed.
Wes harden
That holley TA won't help ya pass even if the the inspector doesn't see it, Holley's tend to run FAT, after you get all the goodies in place, knock the timing back to 4 deg open the gap on your spark plugs another .005". Fresh oil change.
And if your running a Cat make sure the engine is good and Hot b4 it's tested.
BTW the state will send you to a test only shop from now on. I have a guy in Montclair who does all mine, so far passed everytime.
74bronc
I dealt with the EXACT situation in 2001 when I moved back to Commiefornia with my 1974 Bronco. At the time, it wasn't exempt like it is now due to the now defunct rolling exemption. So, I had to get my 351W equipped Bronco through the smog test only one time, but I did it.
Here is my advice. Find a smog shop in your area, preferrably one where the smog tester is a chevy guy. Then, stop in 3 or 4 times and ask the guy specific questions about what your Bronco needs to pass. make up the questions if you need to. this will allow the smog guy to get to know you and get to know your face. This is very important because as a smog tester, a stranger that walks in, could be an undercover car working for CARB trying to see if he will pass a car he shouldn't.
That is the easy part. The hard part is rounding up all the smog stuff because there is just no way around it. you have to put an air system on it and all the other stuff. The 4 barrell won't pass, I guarantee it. The EB never came with a factory 4 BBL, so it isn't in the book and it will be an automatic fail. Find a 2BBl stock manifold, 2 BBL carb, stock duraspark distributor, EGR valve (the manifold will have the provisions for a stock EGR valve), make sure you have a catalytic converter, EVAP canister and Air system. All those parts should be available at a wrecking yard although they are getting harder to find. Ebay is a good resource too. You need to get a stock air cleaner as well.
After you have all the parts, the key is getting the engine compartment to look as stock as possible. Make it look like everything is going where it should. Make sure everything is hoooked up. The 351W looks like it belongs in the engine compartment anyway, so DO NOT mention to anyone you have a 351W in it. Don't ask questions like "my bronco has a 351W in it, what do I need to do to make it pass". As far as the tester guy is concerned, it is a 302. If you try to go about getting the 351W to pass through a referee, you will have to find out what year the motor is and then it will require all the smog devices that came orginally on the that year motor or your truck, whichever is newer.
This can be done. Email me or PM me as I'd be glad to help answering questions. I was a smog tester guy in college, so this is right up my alley!!
good luck
forestguy
Reno, NV
NVraider,
There IS smog in Nevada. Washoe county has you pass a smog test every year. It is just a tail pipe test, no visual. Nevada dosen't care what engine you have in what, as long as it runs clean.
We even have to smog diesel pick-ups now.
wudsrgn
Anaheim Hills Calif
Can't help you but wanted to let you know!
I have the same problem. I just bought a 76 with a 351 from NV. I think it might be like the one guy said just look for a whole mid 70's Fairmont Grenada ect. There's plenty out where my brother lives in Hesperia. Thats what i'am thinking of doing. I Hope for the both of us to meet on the trail someday!
Sac '68 sport
Orangevale
forestguy said:
NVraider,
But it's a different test than we have here in CA. They only do idle in NV, where as CA does the physical inspection, idle, and 25 mph, and I think the levels are lower here too.
I just brought a 79 El Dorado back from Reno and had the smog cert from a shop there and it passed no problem. It failed the CA test miserably. Part of the reason it failed was the timing was not set to the book specs, so watch out for that too. A little timing adjustment, and playing with the AF mixture and she passed no problem.
