Wow. This is the first I heard of these bushings failing
Acetal (delrin) machines super easily. We have a bunch of rod sizes on the shelf, does anyone have a spare bushing that can be sketched up for me? Could bribe the lathe guy and see if I could get a set machined quick. Would want the OD of the metal part that goes through the bushing too.
In theory, same could be done with a harder durometer poly as well. I just hating machining poly since it gums up and is harder to hold tolerance on.
Those things are a B to install too !
Here are the measurements Dlish.Thinking more about this, I don't like Acetal (Delrin) much for the application. Its great for more of a static load and compressive strength is good, but the impact load isn't great. Im thinking the shocks that this bushing have to absorb might break/shatter it.
Nylon....hmmm, wonder what we have on the shelf. Pricey, but some impact modified nylon might be the tits for this.
Yes aluminum may be the ultimate in strength, but I think have some give/flex is important. Maybe I can dig up a couple options.
Chuzie, whenever you find one let me know, Ill dig through the cut-off rack and see if there are any good options.
