Cage Paints
tx1ton
Boerne, TX
Hey all, getting set to paint the cage on my latest trail rig - currently it's raw metal so no prior coatings. What's your recommendation of paint(s) to use? Primer?
I will probably go with Black in color and was toying with Eastwood's Chassis black but am not sure the cost is warranted....will see "some" abrasion I'm sure :D
Thanks!
Joe
crab
I just painted mine with rattle can self etching primer then top coated with duplicolor satin black ceramic engine paint. Turned out great and easy to touch up;D
ugly74
Bronco abuser
Colorado
mine's also just several coats of rattle can splatter paint. I think I did 2 coats of primer, and then I used a couple coats of dark gray "hammered" paint on top of that. looks good, and didn't cost a lot
tx1ton
tx1ton
Boerne, TX
Is the engine paint UV stabilized to hold up on an exterior surface like the cage? Also, Ive seen some engine paints (typically the better/pricier ones from Eastwood or SEM) note curing at 200deg for best durability....that happens naturally on the engine but what about on the cage??
Am I over-engineering this?? %)
matt w
I too just this weekend painted my cage Hammered Silver! The cage got put in the truck this afternoon!
crab
I often forget there are places where you actually have to worry about UV. I live on the Oregon Coast where there is no such thing. All I can say is it looks great. Covered well and can't see the overlaps with the ceramic light texture. I installed 30 minutes after I painted it. I'll go do a scratch test this after noon to see how durable it is. Family cage will require at least 2 cans of primer and 3 cans of paint. I'll shoot some pics later..............CRAB
Dan's73
I likely overdid mine, but I wanted it to match the body color. I had my interns strip, wirebrush, and sand the whole cage (one of Crab's cages), then I wiped it all down & sprayed with self etching primer. Followed with a coat of white epoxy primer/sealer (just like the body), and shot 2 coats of single stage urethane Hot Ginger Poly. Came out great, but not easy to touch up. If I ever have to do it again I'll likely go with chassis black or similar as I've had in the past.
bigjhoov
nobody
Might be overengineering it a bit Joe. It's pretty hard to beat Rustoleoum Gloss Black. Scuff it with a scotchbrite and shoot it.
crab
I went translucent candy orange on my crawler. Two step process......sandblast then powdercoat chrome. After chrome goes the translucent orange with clear in the PC. Looked great for the first couple years but now (even with UV protection in the clear) it is getting blotchy. Thinking about rattle canning black to cover up that $hitty looking $400 powdercoat job.
RIbronco
Costa Mesa, CA
I'm with crab on the non gloss black engine paint, I use the low gloss instead of semi though. A little over 2 years ago, I painted my car's roll hoop with it. There are no signs of fading and were the harness shoulder straps loop around the cross brace there are no signs of wear.
This is what it looked like when put in and looks the same today.
JWMcCrary
I used rustoleum hammered black on the cage, bumpers, and rocker guards. It has held up very well and easy to touch up when needed.
tx1ton
tx1ton
Boerne, TX
I often forget there are places where you actually have to worry about UV. .CRAB
Yeah, we do endure the UV here in TX. On my first Crab cage I did a gloss PC Black but that one's for a street driver where I won't be touching rocks (hopefully!). This one's for a dedicated crawler and I'll likely go with rattle can black semi-gloss. Just ordered some from Eastwood as I've heard their stuff coats better - albeit being a lot more $$'s than Rusto. Also got some of their Acid Primer for S's and G's. I do like the thought of the hammered look so may try some of that in a test spot and compare to the plain 'ol black. Either way touch-up ease is important, this cage will see TX Granite!
Joe
Heus33
Me too but I used a quart can and brushed it on with a foam brush (since mine was already installed). Came out great and is very easy to touch up.
behemoth
i just use the rustoleum industrial flat black at home depot for the cage, bumpers, radius arms and what ever. If I scratch it it easly is sanded smooth and sprayed again.
I used an eching primer first then the flat black.
bronco-13
I used black Rustoleum Bedliner on the 8 pt. Very easy to touch up if needed. B
tx1ton
tx1ton
Boerne, TX
Well I decided to go with Eastwood Rattle-can paints after a lot of recommendations from friends who've used them. So far, after Fedex delivered to the wrong house Sat, I have touched up welds needing it, cleaned using EW Pre cleaner, and primed the cage using their Acid etching primer. I really like how their stuff sprays...no runs even when I mess up %)
Still debating using the EW Engine Bay Black or some Engine Enamel black for the top coat.....
muskrat
Had a race car fabricator install mine. He suggested Krylon black primer. He put it on and it looks great. Super easy touch up compared to other finishes. The flat black looks great against the glossy black of the body.
