my .02 worth (& it may not even be worth that) is that for cams in most 4x4s, less is more, if you need a lot of low end grunt. SBFs need exhaust help, so a dual pattern cam will probably work better. I like the comp cams xe 250, except that I would prefer a 112 deg lobe center cam (like the edelbrock performer has) this decreases overlap and increases low end grunt, but the edelbrock cam is a bit "bigger"than the comp xe250.
We are building a new 302 for my son's 72 soon. Comp recommended their xe 250, he is debating between that and the edelbrock cam.
Went on a bronco trail run recently, the bronco just ahead of me had a pretty healthy 408. My stock 302 did better than his high dollar engine in the rough terrain we were in, even though I have a stock 3spd, 3.50s & 33s, to his automatic, 4.56s & 35s. He could blow me into the weeds on smoothish straight areas, but he had a hard time crawling over ledges, rocks etc. I don't know what cam he has, his idle was fairly smooth, but did have a barely noticeable lope. I just think it's pretty easy to put too much cam in an all around use 4x4. Sure you can build a lot more overall power into an engine, but if it won't pull well right off idle I think it's counterproductive. I would rather have an operating range of idle to 4800 than 1500-5800. Are you really going to rev to 5800? I need to crawl over obstacles more often than I need to rev above 4500. just my opinion.
