Cam numbers for a stock 1975 ford 302 in our broncos
gws34
What is the cam intake and exhaust grind in a stock 1975 ford bronco 302? My Cam gear got chewed up and need to replace but I can not find what stock numbers should be. Anyone have these numbers or can tell me where to find this. I need to pass emissions in AZ so it needs to be very close to stock.
also secondary question, if in the future I want to switch to EFI is the stock cam good for that set up considering I need to pass emissions or is there a better cam that will still pas emissions.
Glen
Contact Howards Cams. Besides a bunch of performance cams they also make a lot of stock grind cams.
Why are you replacing the cam if just the gear got chewed up? Did that cause peripheral damage to the camshaft itself?
Rustytruck
If your changing to efi and changing the cam I would make sure you get a cam with the 5.0 newer firing order.
When he said cam gear originally I assumed automatically it was the large cam gear for the timing chain.
