You are wanting your tourque to maximize in your lower RPM range I presume. When you want low end tourque, you need to build your air intake system, (ports,valves, cam, manifold, carb, and air filter) to maximize velocity. Meaning the method of getting more air/fuel into your cylinders should be by using methods exactly opposite of Hot-Rodding practices such as larger valves/ports/carbs and manifolds. These things along with a high lift, wide duration/overlap cam shaft will do wonders for increasing the volume of fuel/air flowing through your engine and will result in great horsepower increases, but because you have also increased the total volume of your system, it will require high-high RPMS to move the air at enough velocity to feed that horsepower. The key to keeping your tourque range in the lower RPM range of your engine, is keep your ports stock in size or even smaller if there be a set of heads that will fit your block and used smaller ports. A serious clean up and polish on said ports will be highly benificial though as well as retaining the stock valve size. The question of what is an RV cam ? is simplified down to this, generally it is a cam that will have a reasonably high lift and a mild duration. The real key is that an RV cam will have little or even "0" overlap, as overlap will cause the engine to lose most of its low end vacum which will kill your fuel/air velocity. Remember you are not building a lot of RPMs like a horsepower engine would to build that required velocity. I see that you are using 570 cfm carb which should be good on a 302, and I am not familiar with your intake, but if it is for "high-performance," it may not be your friend in the quest for low end tourqe. If I am changing a cam or building a motor, I will always use an RV cam inmy trail machine. Second choice - a stone stock cam will give you a lower tourque band than any performance cam. Any performance cam you might choose will always move your touque band up in the RPM range, but it will usually increase your available tourque noticably if you are willing to use the skinny pedal to go after it. One last thing, be sure that the RV cam that you select will not have such a high lift that your valve springs will coil bind. The best RV cam that I have used, (sorry, I can't remember the specific cam,) it was a very high lift and "0" overlap and required racing valve springs to accomodate the lift. Thats as "Layman," as I can make it, I hope it helps you out some. Bill
