n00bus m@x1mus
- Jul 13, 2013
- 3
Hi all im new here and dont really own a bronco LOL but i do own a 5.0L explorer windsor in an australian built fairmont and im looking for answers about it if anyone has the time to help me out that would be much appreciated.
So the vehicle in question is a Ford AU Fairmont Ghia 5.0L it has the good old 302W with roller cam, GT40P heads and explorer manifold. EFI system has coil packs and a crank trigger and the good old cam angle sensor. So a good while ago i picked it up for a fair price and got it on the road, was running quite well a little underpowreded for what im used to but as it was mostly stock except for the PH 4001 pipes into the stock twin 2 1/4" exhaust and a K&N filter i wasnt expecting any neck snapping power from it. But shortly after it developed one hell of a squeel on startup and oil pressure was dragging so i promptly shut it down and went investigating. This lead to stripping down the sump, timing cover, pump and drive system including the cam angle sensor.... but it wasnt until the put back together stage that i checked the manual and it states i need a special tool to properly allign this sensor. Ford service here has never seen or heard of it and any pics i can find on the net are very vague at best.
The PIP rotor has s single tooth about 4-5 degrees wide and passes a single mag pickup. The tools (which is a simple plastic cap that holds the tooth in place while installing) shows it should sit in line with the crank and the the tooth right against the pickup all aiming at 6 oclock if your standing at the radiator however it doesnt seem to matter where i put it it still acts the same and shows an error code on the scan tool. I have also asked people with aussie built falcons running the same motor to post me a picture of where theres sits when the crank is at TDC no.1 and they are all over the place aswell.... So im lost, i would love a bit better fuel econ from it and at the least a lot more power, im sure it had a lot more go in it before this problem so i hope that if i got it sorted it will spring back into life again.
Thanks in advance for any help.
Clint.
Clint.
