My brand new Motorcraft cam synchronizer is DOA. It has less than 150 miles on it and it won't turn...even with visegrips on it!
I need to order a replacement and hope it has what should be a steel gear since all roller cams need a steel gear (or brass) and all 1999 Windstar 3.8's had roller cams... so in theory they should all be steel. Right?? Well, this is Ford so... lol
Dang...glad I checked it before it went back in...and how did it NOT seize up in the motor? I mean the engine was running fine, I pulled it, and since I'm doing some major engine mod's I decided to check cam gear depth (again), I checked the oil pump shaft "end play" and luckily found that the cam sychronizer wouldn't rotate (espcially before installing it in my new engine on Thursday...)
No way I got this mixed up with the couple others I have... maybe I did but it looks brand new...
