camber/castor question
polecat
Yakima, WA
I recently installed the stonecrusher steering setup and adjusted the toe-in correctly, but I think the camber/castor needs to be adjusted. Looking at the front of the bronco the tires seem to be leaning out at the top too much. Is there a home adjustment, or do I need to take it to an alignment shop. By the way, I have done the F-150 front disk swap last year.
Thanks for any help
johnny
wildbill
Old Bronco Guy
;D ;D ;D Take it to a shop that dose trucks and 4X4's. Thry make tapered shims that bolt on and they can get the right degree for you and you can go home and put them on. As I would think today it would cost over 250.00 to 400.00 in labor to do it. But it is real easy just time good luck. ;D ;D ;D Bill :cool: %) :p
Matt20AE
IL now WI Normally
im sure that someone sells a camber kit out there just look around. I think that would be your best bet, you could do it yourself and save some money
chuck
Ingram, Texas
It sounds like you have a D-44. If that is so there is a concentric adjuster that can be installed in the top ball joint that should fix your camber and its not that much work to install them.
P
polecat
Yakima, WA
yeah, chuck it is a d-44. The concentric adjuster allows for a pretty decent window of adjustment? I take it that you sell them? Thanks for the help.
johnny
airman
I think the adjustment on the ball joint spacer is only 1/2 degree.
When you say it is out how far out is it? I thought I saw at one time another device that went under the spindle to do it too.
