matts70
OK, I've been chasing a timing issue for a while now (http://classicbroncos.com/forums/showthread.php?t=155660) and have received some great help and ideas from lots of people here. I thought it would be better to start a new thread for this question because it's more specific.
My compression in all cylinders is 130-150 psi. Can I still have a valve timing/camshaft timing issue? If the timing gears are off a hair (1-2-3 teeth?) could this cause the initial ignition timing to be advanced 30* (600 RPM, no vacuum), but still maintain good compression in all cylinders? Is it even possible for the timing gears to be misaligned on a 302 with stock timing gears?
I've done the following while trouble-shooting this situation: rechecked idle mixture on carb, installed a new dizzy, checked TDC on #1 cylinder, ensured rotor is pointing right at the right plug wire at the right time, checked timing chain play (OK--5*), replaced the damper, checked the timing marks on the damper, checked proper voltage to the coil, checked compression.
