Can headers help reduce engine temps.
SteveL
Huge chevy guy
Hawthorne ca
I had an old suburban with a 350 that ran great out here. When the water pump went I put on a high flow pump on it I think flowkooler. I ran into the same temps you describe. I put a stock pump back on and everything was fine. All I could figure is the hi flow was either moving the water too fast or causing an issue where the stat wasnt opening.
A
Asanjuan1
Monrovia, CA
SteveL - I also have the Flowkooler. I've heard of this occurring. I installed mine after the heating began, no change. :(
bronconut73
[ , and smaller lower pulley....whew! ]
You want the largest lower pulley that will fit with the smallest water pump pulley.
If you run v-belts then BC has the smallest wp pulley and the largest crank pulley that will fit.
