I had an old suburban with a 350 that ran great out here. When the water pump went I put on a high flow pump on it I think flowkooler. I ran into the same temps you describe. I put a stock pump back on and everything was fine. All I could figure is the hi flow was either moving the water too fast or causing an issue where the stat wasnt opening.
