Moon's74
This thing is driving me crazy...or maybe it's just too late.
302/470TA/performer/MSD/stock dizzy
Engine idles fine, but loads up, sputters, at higher rpms. Basically, no power.
Replaced power valve and jets on carb.
Back 4 spark plugs are very black, front 4 plugs are light brown...just right. What gives?
I can't seen to get the timing correct. I've read that vacuum advance should be on manifold vacuum (ie full time)? Wait a minute, I've also read that it should be on the timed spark advance on the carb? Which one is it?
Also, with no vacuum to the dizzy my timing is way advanced, like 40 degrees. Checked the harmonic balancer position with #1 at TDC of compression stroke, sits right a 0 on the pointer. Start it up and the timing light shows 40 degrees advanced.
Checked the vacuum diaphram on the dizzy, it works correctly.
Tried to retard the timing and it loads up really bad and will not run.
With timing at the advanced, original, position I revved up the engine and it advanced even more...without the vacuum connected. No change with the vacuum connected to the timed port on the carb.
Where should the transmission get it's vaccum from? Tranny and PCV are on bottom front of carb, back port is plugged for lack of brake booster.
My apologies for the long post, but I'm baffled.
What am I missing? Thanks.
