Can't get my headers off easily-- strange setup
Bundy
I don't know what kind they are...
but in trying to remove them i have found it is not going to be easy for a few reasons;
First, on cylinder #1 and #5 the inside bolt is so close to the header you can't back it out because it makes contact before you can get a full turn in.
Second, the inside bolt looks like two nuts on a stud... why would someone use that setup and how am i supposed to get them off?
Third, the header's flange is tacked to the pipe... it's the only one- any idea why?
getfuzzy
The bolts look like some old rusted Stage 8 locking header bolts. Is the hole in the center for an Alan wrench?
broncnaz
All quite common issues with headers. Most of the SBF headers I've ever installed or removed had issues with a few of the bolts. Just got to work it. A for the tack weld on the flange hard to say most headers are fully welded from the other side but maybe yours are not.
Bronc76
Looks like flange is bolted on and then the tube was tack welded. Could be homemade job?
Bundy
Bundy
it does have an allen center but i couldn't get one fully inside- do they make a shorter allan wrench? looks like i get to add to my list of special tools that only work on the bronco lol
any guesses on what manufacturer they are? or you think they are custom?
StnePny
Santa Monica, Ca.
On that on you will have to take the spark plug out & use (I think) a 7/16 open wrench (no roon for ANT type of Allen wrench) with VERY samll turn
Once you have all the other bolts out, that one will loosen BUT you will not be able to take it out, remove the header with the bolt in place & remove it when the header is off
that header & flange (tack welded) is normal (for very old school)
I have had my (new) Stage 8 bolts & headers on & off a few times and the one bolt meets than bend - no if's, end's or but's
To me it looks like a set of old Duff Headers with Stage 8 bolt with no locking ring or clip
Bundy
Bundy
Thanks for the reply- i think you are right. i am able to turn the bolts a half turn and the header comes out just enough to get another half turn in- tedious but what isn't on a bronco. thanks for helping me work this out.
is there a better fastener setup i can replace this with?
should mine have had some sort of locks or retainers like these new kits?
barronj
If it makes you feel any better, outside of stock manifolds, this is what I expect to deal with when installing/removing headers.
73stallion
Eugene, OR
those locks are a PITA IMO. get some good bolts and use some sort of lock washers. i NEVER have a problem with my bolts loose, and i have no locks.
