Back before the world went to front disc brakes, a lot more attention was given to front brake replacement.
Arcing the linings to the drum contour was necessary for a good brake job, that wouldn't pull when applied. Most brake facilities don't even have the equipment or knowledgeable employees to do that anymore.
The best you can do is to make sure the brake shoes are assembled correctly for the side they are on, and they are adjusted the same on both sides. Also, make sure one of the wheel cylinders isn't stuck.
