Carb Guru
Gray035
Encinitas, CA
Question for those of you who know carbs better than I do. Does this choke look right? I thought it worked either on vacuum or it was electric, not both. Is what I have in the picture right?
73azbronco
I don't think the tube is for vacuum, it's for heat off the exhaust manifold. If you open that up, does the inside look black from soot of drawing in air by the exhaust? I could be wrong, I'm more tuned into one barrels.
jckkys
There's no reason not to use heat from both sources. A choke that opens quickly is an advantage. The heat from the exhaust manifold remains when the engine is turned off for a couple hours, so the choke won't close wasting fuel as the engine is still warm. The electric cap heats up faster after you first start it in the morning.
msommer001
what is the power source for the electric choke, I am thinking about going that way, I assume it heats up what the key is in the on position, but does it ever shut off or just when the key is returned to the off position. In that case, do any feed activated by the key good enough?
broncodriver99
Glen Allen, VA
If it is an original Autolite/Motorcraft electric assisted choke then you can use the stator terminal on the back of the alternator. If it is an aftermarket 12V choke then best to use a switched 12v source like the switched ignition lead on the voltage regulator.
jckkys
If you run an electric choke off the ignition it's a good idea to put a oil pressure switch in the circuit so the cap isn't being heated when the engine isn't running. Simply using the stator lead on the alternator is a lot easier and does the same thing. I've done this with Motorcraft, Holley, and Edelbrock electric choke caps and they all work fine.
Again if you have a 289 or 302 with original cast exhaust manifolds use the choke heating chimney also. All the parts needed are available at Mustang restoration suppliers.
