Not sure I saw the suggestion to confirm firing order but if leakdown test and compression test come back good i would double check the cam firing order with the ignition firing order.Yes. Normally.
But for now I wouldn't rule anything out just yet. At least the steady needle is a good sign, but I would not consider it a guarantee just yet.
You said you had spark to all cylinders, even though certain ones made no difference when pulling the wires off (a bad sign in itself of course) but were they all good looking sparks? Not yellow or red, but nice and crispy blue/white with a nice snap to them?
If so, then it would seem an internal issue. Maybe...
It's just strange that all cylinders check with nice high and very even pressure numbers, if something inside them is jogging combustion. You would think it would show up with a compression test.
What about the intake design as a clue. Are all the bum cylinders on the same plane of the manifold?
And here's another oddity. If they all have such even pressures, and all have good spark, but those three don't seem to make any difference when you remove the spark, then how were they within 10 degrees of each other in the exhaust temps? Only #5 cylinder has both issues showing up during tests.
What were those temps by the way? If lower or higher than normal, maybe it will lead us to another potential issue.
Maybe they're all getting a bad mixture or the timing is farther off than you think. Could the timing marks be wonky? Did you check the timing during all this messing about? Or were you quoting numbers from a previous tune?
Good luck.
At the same time check for a wiped cam lobe or two. Wiped Cam lobe wouldn't show on leakdown.
Sent from my SM-G900V using Tapatalk
