Carb question
Millar
Birmingham
Afternoon,
The carb that came from the P.O. is one fussy filly. I have re-built it and had a mechanic re-build my re-build and there is still a hesitation/backfire when I put the coals to the pedal. I am getting a re-man 302 engine from Jasper and was wondering if a new 2 barrel carb would be a wise investment. If so, care to share any suggestion on which one to buy? Hell, I would even consider a 4-barrel if it would be a solid upgrade.
Thx all. I would be lost without this site.
Millar
broncnaz
X2 what carb? Is it the correct sized carb for your engine? If not that could be part of the issue and it needs some tuning.
Biggest issue is there are not really any new 2v carbs that as good as the stock 2100/2150 carb best you can do is a remanufactured one. Which in most cases is really little more than a rebuild which you have already done. I would suspect you have a tuning issue maybe ignition timing, A vacuum leak or the engine has issues that may be solved with your new engine.
jckkys
Ditto. If you still have the original '71 2100, that's as good as any you'll find, don't give it up for a $20 core charge when buying a rebuilt if that's your choice. You would be lucky to get all the correct parts in any high volume rebuilder. A specialty rebuilder like Kurt Praxl of KP Carbs can give you a rebuild with all the quirks resolved and a better than new finish, but this is more pricey. On the other hand I can't find anyone who wasn't happy with the results. He really knows these carbs.
Fairlane514
Houston
Where is your initial timing set? Did your engine ever run right? Maybe its not the carb, maybe its ignition.
Millar
Millar
Birmingham
Thanks boys! All good info at usual. I have a MotorCraft 2100 and it might be the original one, but I dont think it matters. I am not sure where the timing is set on it right now. Once the motor is dropped back in, I can fuss with the other suggestions and dial it in. I am glad to hear the current carb is a good bet to keep. I like that idea best. I will just need to take care of that Hooker when the time comes. I will just cross off a carb as things I might need to get.
Thx,
Millar
A very common issue is mis-matched gaskets and base plates too. Between aftermarket manifolds (if you have one), multiple choices from Ford for the base plates and gasket styles, it's extremely common to have a mis-matched set giving you fits.
Whether as simple as a vacuum leak, or perhaps something covered that shouldn't be, or uncovered that shouldn't be (heat passages and such) there's lots of chance of funny business.
Have you checked for the basic vacuum leaks with a spray fluid of some kind?
Have you verified the rest of the tune? Sounds like not yet, since you're not sure what the timing is, but that's a big concern. Distributor issues often crop up like carb problems. And the wrong PCV valve for the engine could result in a lean-misfire and coughing through the carb on acceleration.
Remember... If you can't fix it with a hammer, you have an electrical problem.
Or, as Dr Jacobs used to say... "90% of carb problems are the ignition system. And 90% of ignition problems are carburetor related!"
I would pull the top off the carb again and check what size the main jets are. You will probably want 50 or 52 on a stock motor. 46 or 48 at high altitude. This will point out if the carb is a parts swapper. hesitation / backfire is usually a lean misfire due to a vacuum leak or not enough fuel when accelerating. Check the accelerator pump rod, check to see if the rod is one hole from the top.
jckkys
Paul makes a good point. Potential vacuum leaks from mismatched intake mounting surfaces, carburetor gasket surfaces, carburetor spacers, and mounting gaskets, can be a PITA. If the OE 2100 is used, the OE cast iron intake, and OE aluminum spacer are the best there is. The tendency to "upgrade" to an Edelbrock Performer intake and after market 4bbl, invites these leaks. The Performer intake has a skimpy carb mounting surface that only seals with a solid spacer under the carb in many cases.
Mansen
Also, cold engines backfire like lean engines and blow power valves, then your rich.
