The idle stop solenoids were only there to deal with dieseling or run on after the engine is shut down while hot. The emissions settings included a more open throttle, just to idle. So there was enough air for the engine to run on with no spark. With the solenoid, when the ignition switch was killed the solenoid let the throttle close completely. If the idle and timing are set to run well, there is no dieseling, so no need for the solenoid.
The diaphragm is a more positive de-choking device than the piston in the choke housing. They work well, far more useful than Autozone counter guys. They were part of '71-'74 2100s. The earlier 2100s didn't have them and 2150s came out in '75. You can get them at Walker Products part #64-278;
https://buy.walkerproducts.com/carb...d-2bbl-2100-2150-7-carburetor-components.html. AC wasn't an option on early Broncos. Either a PO or dealer installed it.
The hose nipple filled with silicone supplies filtered air to the heat tubes. You want it. You will learn that previous owners are often knuckleheads. I doubt your 2100 ever had a manual choke, but it did have an electrically heated choke cap.
