Newbie here. Not only new to the forum but also to tinkering with cars.
Talked my wife into purchasing our first EB bronco last summer. Since I have been obsessed with them since I was 16 it has been a long time coming (not as long as my father in law's dream of owning a corvette that was recently realized... 38 years). I probably over paid for it based on the fact that the body is completely rusted out, but mechanically it was pretty sound. Until last weekend.
We took it our for spin to enjoy it and kaput. The carb wasn't getting any gas. I don't think it is the fuel pump because when I disconnect the fuel line from the carb it spurts gas all over the place. I think the nozzle that sprays fuel into the carb is clogged (probably not the technical term). HOw would I clean this or do I need to purchase a new one?
In trouble shooting this issue, I developed a secondary issue. When trying to turn over the engine, I held the ignition switch down for a while while pumping the gas. I then turned the key to the off position and took it out, however it kept trying to start as though I had the key in and turned all the way to the right! Something was stuck for about 45 seconds or so. Do I need to replace the ignition switch or can I just lube something so that it doesn't stick again. If so what do I use.
Big fan of the forum. I can't believe the knowledge on here nor can I believe the modifications you are all able to pull off. Very impressive. Here's to learning!!
