Hi everyone,
I am having an issue I am wondering if you all might be able to help me diagnose. I did a bit of work to my 75 Bronco and got it up and running, tuned the carb and replaced a few things (fuel pump, harmonic balancer, water pump, timing chain, and distributor). It's been running great, but as of late it is having a difficult time catching when I turn it over cold. Essentially, I need to crank the engine for so long the battery starts to get weak, then eventually it catches. After I run it, I can fire it right up again after I cut the engine, as long as it doesn’t sit too long.
My assumption is that the float bowls are emptying while it sits and I am cranking the fuel pump to fill them up before it will actually ignite. I don’t see any fuel outside of the carburetor, so I am wondering if it is leaking down into the manifold. My reason for thinking this is that the first crank fires up immediately for a split second, then the engine dies and the long crank-time begins before finally starting.
Any ideas on where to look to fix this?
Carburetor is a Holley 1850-2
