A big thanks to Chuck at BC Broncos for sponsoring this ClassicBroncos giveaway!
Prize: Heim Studs and Drag Link Saddle from BC Broncos
Description: This kit includes 3 heim studs, 3 cinch nuts, 1 saddle bolt and 1 saddle
The Heim Studs - "The chromoly tapered shank will fit the F-150 tierod end hole in your knuckles and pitman arm and provide a good solid mounting point for the heim joint rod end."
The Mounting Saddle - "The saddle is made to fit our 1 1/8" tie rod, it is constructed of 1/4" plate steel. They come welded to the tie rod. They are offered here as bare steel only. They can be used for the track bar of your tie rod or for ram assist."
Remember, to use these parts you'll need heim ends on your steering system. If you have any questions about what's needed or how these work please ask.
The Rules:
Who can enter? - This giveaway will open to forum Contributors only as a way of saying thanks for helping support the site.
How do you enter? - Please post in this thread if you want to be in the drawing. That way only those that actually need the parts will be picked.
Deadline? - The winner will be drawn randomly on Monday June 27th (all entries in by 6:00 PM)
Good luck!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![saddle.jpg](http://bcbroncos.com/store/images/saddle.jpg)
The Rules:
Good luck!
