Centech harness and HEI distributor
JWMcCrary
Installing a new harness and using an HEI distributor. Never used HEI before but seems only 2 wires to connect, tach and 12v. I'm assuming I can use the blue ignition wire and ignore the other wires in that bundle ??
rydog1130
There should be a wiring diagram included. I ran the centech w/ a msd ready to run distributor and only used the blue wire omitting the violet and white wire. I had to kinda guess with mine as they didn't provide a diagram with that set up, but I know theres a diagram for yours and it does sound right
Using the Blue makes the most sense from what I remember. And you no longer have to even have the White (and isn't there another shade of blue in that bundle too?) wire connected to the starter relay or in the connector.
Just 12v in RUN only, and that's it to make it run.
Do you have a body lift or other help in clearing the hood? What about the air-cleaner? Running a stock one?
JWMcCrary
JWMcCrary
Actually it does give some direction in the instructions, I just missed it. You do use the Dk Blue ignition wire.
Plenty of clearance for the distributor Paul.
