Centech Solenoid - Ignition question ..HELP...
Jay1clarke
Solon, Ohio
I am running a Centech Harness and read these posts and realized I screwed up somewhere with the longer violet start wire. I am using the resistor, dura spark set up.
The longer violet wire as I understand it goes to the neutral safety switch, right? I screwed up and cut it and connected it to the solenoid (it made sense - was right there and the instructions said violet wire). Guess I'll solder it back together and make it long again.
The shorter violet wire that comes off just past the fire wall (with the blue and white) runs to the ignition box. Does this violet wire that runs to the ignition box also get spliced and also go to the solenoid?
The instructions on proper solenoid wiring suck and contradicts itself between the information guide and information phamplet.
If anyone could tell me the proper routing of wires to the solenoid, it would be of great help.
Also, what is the best place for the resistor - on the firewall creates wires everywhere, kind of looks messy there. Any better ideas, I already want to relocate it.
I don't think you screwed up Jay. Or at least interperet that as "don't re-splice the wire, just yet" anyway!
Are you indeed running an automatic trans, where you'd need the Neutral safety wire?
I'll have to re-read the instructions (no, it's not you, they're pretty poorly written in some areas) before I talk about the NSS, but your starter hookup sounds correct so far. One (only) of the Violet wires does hook to the solenoid's "S" post.
I'll check and get back to you later. This was just so you didn't think you were suffering alone. And to bring it back ot the top so that other Centech-savy memebers can jump right into the fun!
J
Jay1clarke
Solon, Ohio
RE: Centech
Thanks, Paul. I do have a c4, so need that 2nd violet wire. The other violet I don't have to the solenoid, I have it directly to the 2 plug connector into the ignition box (amp) - that is where the instructions told me to put it (instructions say blue wire to the red, and violet to the light blue - white on mine. That leaves my solenoid with just the white wire.
It also says to hook the batt wire, batt cable, and yesllow on one large post on the right I am thinking this should be on the right and the starter cable on the left.
Also, are there any direct wires from the alternator to the solenid? With the durasprk set up the instructions don't run any there, rather one to the regulator.
When you say "left" and "right" posts, are you speaking in the proper terminology regarding the left and right side of the vehicle? Or left and right as you're looking at the solenoid? The wires you're refering too would be on the left side and the starter cable would be on the right, as you would see it when looking at it from the front. Just so we're straight.
Might not actually matter, function-wise, but this is how they're typically wired up.
As far as the alternator wires are concerned, you would only need to hook a separate output wire directly to the solenoid if your using a higher than 70 amp alt. In that case you would not normally use the Centech's Yellow alternator wire.
So if you're running, say a 130 amp 3G or something similar, you'd run a large-ish gauge wire from the "BAT" or the "CHG" post on the alt, directly to the "left" post on the solenoid, which would, in effect, be hooking directly to the battery's positive cable.
Otherwise, if you're using a 70 amp or lower alt, the large Red "BATT +" goes to the solenoid's battery side and the large Yellow "ALT +" wire goes to the back of the alternator.
On our older Fords, these two different colored (orignial colors were Black w/red stripe and Black w/yellow stripe) wires are one and the same wire. They're joined at the ammeter gauge and create the charge circuit. Going from the alternator, into the cab, through the gauge panel (through the ammeter's inductive loop), the fuse panel and then back out to the battery, via the large post on the starter relay/solenoid.
Works fine for lower power, but the circuit's length and relatively small gauge are why you can't use it (safely anyway) for a higher output charging system.
When you're looking at the solenoid/mag-switch/relay/thingy (there's some argument afoot about what it really should be called), your battery cable and large Red "BATT +" wire should be hooked to the large post on the left.
Your Violet wire should be hooked to the small post on the left. They're typically marked "S" for switch, but not always.
The small post on the right, which might be marked with an "I" for ignition is where your White wire (marked with maybe an "IGN +12v" perhaps?) goes into the harness and comes out at that 3-prong plug with the Violet, Blue and White wires. It's used for either bypassing a resistor, giving a full 12 volts to the ignition during start, or to give a starting signal to something (such as a Duraspark box, if needed) while the starter is spinning. Otherwise that White wire is dead the rest of the time.
Sometimes you have to sit and think about all that to have it make sense (especially after I butcher it!), but once it makes sense, the whole rest of the harness makes more sense too.
More to come...
And just so's we're clear here, what alternator system are you planning to use?
J
Jay1clarke
Solon, Ohio
Called Centech
I called Centech and they answered my question. The new and old harnessess are built for manual trucks - as most were in fact manual transmission trucks.
The 1st violet wire that comes out with the wires to the ballest resistor goes to the ignition box (2 or 3 plug).
The 2nd violet wire needs to be pulled back through and come out by the first violet wire. This violet needs to go to the neutral safety switch first, then come back to the s post up front.
The new harness only has 1 yellow and one orange to the alternater. No ground and nothing to the starts terminal on the back of the alt.
The batt wire, yellow, and + battery cable all go to one side of the
solenoid. the otherside obviusly is to the starter.
What is so simple, became so hard! But Centech explained wbverything to me, even why the eliminated, and did not add a specific Neutral Safety Wire. Good folk, good support.
Off to the rest of this pile of wires.
Looks like the NSS circuit is pretty basic and that, yes, you have to kind of make it up yourself.
So it's up to you to splice the NSS in between the key and the starter relay.
Guess I was wrong about the way you have it hooked up then. You ARE supposed to cut it somewhere and run the switch, then continue it up to the solenoid.
The other Violet wire is not meant to be part of that NSS circuit, but instead is an additional "START" signal for, as I mentioned above, something that needs an additional start signal. Such as, in your case, a Duraspark module.
Just so you know, in case it comes down to you having to wrack your brains on how to run another wire, your Duraspark box will still work, even without that extra start-signal circuit. I would bet that most of us here don't have that wire hooked up.
As for your NSS, do you have an original harness from your switch still? Seems to me that your switch has a pigtail long enough to reach up past the bell-housing. Is this correct? If so, then all you have to do is to run the Violet Centech wire in one side and out the other and on to the starter relay.
I forget what color the wires are (Blue w/red maybe?) but the backup lamp wires are Black w/red, so whatever the other ones are, they're your neutral safety wires.
Which all means, yes, you'll have to pull the wire off the solenoid and re-configure it to the NSS first. Oh well. I'm sure you did an ultra-clean install on that one. Took your time and all. After all, that's the only reason you'll have to re-do it. Next time don't do such good work!
Regarding the ignition, you'll be using all three colors on the Centech harness from that 3-wire Weatherpack connector.
Blue to the ballast resistor. From this end you can run another wire to the Red wire on the Duraspark module.
White to the other side of the resistor (the end with the coil's "+" wire) and out to the coil.
Violet to the White wire on the Duraspark module.
Assuming you have a Blue-grommet module, that is.
Good luck.
J
Jay1clarke
Solon, Ohio
RE: Centech
Thanks Paul! This helps. I am running the stock style alternator right now. Yeah, that's what you do with the 2nd violet on th enew harness (run to the NSS, and back to the solenoid post).
If I did it again, I would change out my alternator and distributor - this stock stuff is just too much wire! I'll upgrade and eliminate later, need to drive this thing already.
J
Jay1clarke
Solon, Ohio
Re: Nss
RE: Yes, I have the stock wires on the trans that run long enough to connect by the heater hoses. I do not have the harness side plug (am looking for one - would like to keep it clean).
So the red and the black I take the back up lamp wires to on from the Centech - haven't gotten there yet. Do I tie the violet on the NSS into both wires - all together - one wire? Sounds like it doesn't matter, as long as it's not the red or black side.
J
Jay1clarke
Solon, Ohio
Finished it all up - had everything perfect, and there were to many wires, so I tore it back out and installed an hei distributor. I recommend no one use stock duraspark when rewiring! the hei is so much easier and a nice clean look.
True. Unfortunately though, using an HEI leads to other changes on some other Broncos. Air-Cleaner and hood clearance for a couple. Wiring is a no-contest though, that's for sure!
