Changing 76 steering to 75 steering
Attac
Little help guys/gals
Just put 3.5" duff SL in my buddies bronco. All new bushings.
Steering box has a little play and it is the 76 QR but when you hit the slightest bump or go around curves steering is really wonky. Have a replacement box on the way but I know about 3.5" is the limit on the y steering before having problems. I have a practically new setup I took of my sons 75 when I put the one ton tie rod steering from ruff stuff on.Will the 75 steering bolt up or are the knuckles different. I do have a 7 degree reamer.
Chuck
spap
Did you use and adjustable track bar.
I have had a 76 and a 77 both with 3.5 SL never any problems with the inverted y.
Not as strong and the earlier version s both shouldn’t be causing the problem
Crawdad
I had a 3.5 on my 76 years ago. After having alignment and toe-in it still left me driving without much confidence. It was squirrelly and it bothered me anytime above 60 mph. I’ve since sold my 76 and now have a 77. It will get the WH 76-77 T-style steering since I plan on running a 3.5 again.
Attac
Attac
Track bar and steering linkage are still parallel after the lift?
Yea they are close
The big difference is that the PO had pieced together a 2.5" lift. Was like driving around in a bulldozer. We put a duffs 3.5" system in it minus radius arms. It is much softer now. That with the fact that all of the bushings were changed and tightened everything else up and so with the movement of the new suspension it all comes back to the steering wheel. We just got it aligned and a good shop that i gave the alignment specs from here that is known to work well. Had to buy a 1.5 degree alignment bushing for the right front but we have it all in spec now.
I have a good new set up from a 75 that i think was one of the aftermarket heavy duty 1/2 ton sets.In the adjuster both the ends touch to be at @ 48"
I need right at 50" for 76 knuckles. the Adjuster is about 8" long so i should be fine. I am gonna ream the knuckles and pitman tonight and install the new steering.
I will report back on the difference
Chuck
If they were before a lift, they will be after a lift. Until other things change...
The fun starts when you start changing other things, such as converting a '76/'77 EB to T-style steering. In that case you change normal behavior and don't use a trackbar drop bracket, but still use a dropped pitman arm.
You don't use a trackbar drop until you get to the taller lifts that is. And the normal EB dropped pitman arms are too steep. So you end up using the full-size Bronco/F150 arm with less drop, and no trackbar drop.
This puts the two bars back to almost perfectly parallel.
This setup works great with 2.5" lifts, pretty darn good with 3.5" lifts, but would need to have more help at anything over that.
Just like they do with more than 3.5" lifts even when you haven't changed the linkage.
