Hello all,
I had my power steering gear rebuilt by Lee manufacturing in CA and had them change the steering ratio at the same time. My question is for those of you who have already done this. How much harder is it to steer after you made the change from what it originally was? Before the switch, it was pretty much one finger easy, now I almost need two arms to turn the wheel. At the same time I replaced the lower steering shaft with the collapsable unit from Wildhorses (a really nice unit by the way), and I recently replaced all the other steering components, so there is basically no play whatsoever. Anyway, I am thinking that maybe the box needs to break in a little, but I guess since there is less turns from lock to lock, you don't get as much of a mechanical advantage, hence the harder steering.
By the way, kudos to WH for having the shaft made and to my door within 3 days, just like they promised. The shaft looks really nice, and it has absolutly no play in it, very clean looking once in too. The install was fairly easy, but an air wrench is needed to take off the plate from the upper shaft, the part I had the most trouble with. The shaft is a little expensive, but I had quite a bit of play in my old shaft, so the new one makes driving the Bronco a joy again; no worry of the next bump that may turn the wheels sideways without my hand moving. Interestingly enough, the most play in the old shaft cam from the splined area by the rag joint, not the u-joint near the steering gear. So for those of you with loose steering, take a look at that. Sorry for the long post!
-Eric
-Eric
