Changing Diff and Trans case fluids
HigginsHorse
I've never changed differential or Transfer case oil before. I would like to do this without dismantling the drivetrain, if possible. I have a dana 44 in the front and Ford 9" in the back. Trans case is stock, as far as I know. Can anyone provide a pic of what the drain plugs look like? Is this as simple as removing the drain plug, sucking out the old oil with some tool, putting new oil in, and replacing the drain plug? Having never done this I don't want to neglect or miss something out of ignorance. I have enough of that already.
Thanks for your help.
HigginsHorse
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
The T-case is easy, it has a fill and a drain plug. The diffs only have fill plugs. If you have some sort of sucker-outer, the Dana is pretty easy. To do a decent job on the 9", you'll be best off drilling and tapping for either a drain plug or a better located fill plug on the back of the punkin.
Tip: Never pull a drain plug before you pull the fill plug. There's always a chance of threads stripping or the plug being rounded or your ratchet breaking etc... and then your screwed if it's already drained.
astark
Bronco God
The steep hill method works good as a next best alternative to the above and is commonly used in Arkansas. I have a steep slope at an old abandoned rock quarry I use. I park nose down as steep as I can to do the front differential drain, then coast flat to fill. I do the same thing pointing uphill for the transfer case. Then park driver side down and side ways along the slope to do the rear differential. I use 80-90wt gear oil in all three and have had no problems, but others use 140wt and even 50wt motor oil. The 80-90wt in my opinion is the best year round choice.
H
HigginsHorse
Anyone have pics of Trans case plugs
Does anyone have pics of the Drain and fill plugs on the Trans Case. I haven't been able to locate what I think is a fill plug.
HigginsHorse
H
HigginsHorse
Excellent!!!!
Excellent!!!! Thanks for the Pics. Exactly what I was looking for.
HigginsHorse
supermottl
Indian Harbour Bch,
for the D44, you could also pull the front diff cover off to drain and clean out any crap that's in there. Then replace with a nice crome job... it'll look groovy...
