- Joined
- Nov 3, 2003
- Messages
- 51,651
No. The '76 and '77's that had the higher mounted plastic canister over on the passenger side firewall do not use the condensing tank behind the driver's seat.
Only the previous years that used the steel can down low on the frame rail had that.
And I guess that Greg and anyone else doing it successfully the way he describes are just lucky.
The way I understood it, you're never supposed to hook uncontrolled vacuum to a vapor canister. The only reason computer controlled vehicles do is because they have an actual control circuit (CANP, or canister purge) wired into the computer that can control when the valve opens and closes.
Uncontrolled manifold vacuum can literally pull liquid gas up into the canister.
Granted, it's hard pressed to do so with it mounted so high, but even still, I don't see anything wrong with doing it the way Ford did it in the first place. Just let the intake charge pull it gently out and into the air-cleaner housing.
If you've got a computer and harness that are compatible with a CANP valve, by all means. But on a carb'ed engine, just let the carb suck it in. Not the full manifold vacuum of the intake.
The way the stock '76 would have been connected is:
1. Small fitting to the tank(s)
2. Medium fitting to the carb float bowl vent.
3. One of the large fittings would have a mushroom cap to allow atmospheric pressure balance but keep the crap out.
4. Second large fitting has a hose run to the side of the stock air filter housing and gently pulls the vapors out of the canister and into the engine intake air charge.
Pretty simple.
I've got pictures of a stock '76 here somewhere if I can find them.
Pretty simple.
