Chatter from Starter/Flexplate
Ches7911
OKlahoma
If there’s another related thread please direct me to it
I recently attempted to blow the cobwebs out of my ‘75. It’s a 302 w/c4. At first I thought the noise was coming from passenger side engine, but not really a knock. It was hitting consistent at idle and changed pitch and speed with throttle. After climbing all over the thing it was loudest near the starter/bell housing. Ran through a few of our forum checks and found a couple relating to the starter & flexplate. I jerked the starter off and noticed some fresh markings on the flexplate. Starter also had a little wear but not much. I pulled the cover on the starter and found the arm was a bit sticky, not allowing the starter to fully retract. I cleaned it up, lubricated and stick was gone. Reinstalled, fired it up and acted as though that was the fix...until I put it in reverse. Now the noise is constant in reverse but not much if at all in park or drive...any suggestions? Am I chasing the wrong fix?
spap
So happens to me once the ring on the flex plate was coming lose, kinda of happened every once in awhile then got worse, took the c4 inspection cover off and I could see where it was separating.
Ches7911
Ches7911
OKlahoma
Thanks spap, I’ve run myself out of days off but in a couple weeks when I’m back I’ll pull the plate and check it.
spap
It’s sucks if that’s what it is, a lot of work
Good luck
Ches7911
Ches7911
OKlahoma
SPAP - finally got back from work to look over the bronco. I pulled the inspection cover I don’t see anything unusual looking or any cracking. Left the cover off and started it up. I can definitely hear a hellashis noise coming from there. Am I going to have to pull the tranny you think?
Ches7911
Ches7911
OKlahoma
Update - thread may not be useful for but for an amateur maybe it’ll help. So I found when I run my bottom starter bolt all the way in, the c4 dust cover is making contact with the flexplate weight. I took a video because I’m not certain how much wobble is normal in the flexplate while it’s running. (I’ll figure out how to share that later) I bent the dust cover for some clearance and put it all back together. No more noise but may still be out of balance at this point I just want to drive the damn thing
diggs00
glad you found the culprit without having to pull the trans. better luck than I had
Set up a google drive account (free) and host your video there and you can share a link to the video.
