Chevy disc brake conversion question.
LSUpete
I know this has been brought up before, but I need a definitive answer from some of you guys who KNOW what they're talking about....not guessing.
Here is my setup: All new brake lines and hoses, new brake booster setup (BC's), Chevy disc conversion, stock proportioning valve (from Lars).
The problem I have is that the brake pedal is very weak for the first 50% of it's downward travel. This gives the illusion of NO brakes up until the time the driver puts the pedal on the floor....then it stops on a dime. I've bled the hell out of these brakes, so please don't offer that suggestion....unless you want to see a mushroom cloud develop over Key West
Any suggestions?
66horse
Pete,
Mine do the same thing. Try this to narrow it down first. Unplug the fitting into the booster and see how your pedal feel is. It is my understanding that by taking that out, you are running the equivalent of non power brakes. Basically checking the booster here.
Second, adjust your rear brakes. there should be just a real slight drag on them without brakes apply.
I have the same exact issue. Brakes work awesome, pedal feels like shit.
kwspony
Roseville
I have a simular problem. the brakes work fine, the peddle feels fine but for some reason the brakes apply before the brake lights come on. tried adjusting everything but still have the same problem. I have also noticed that when I push the peddle down just a bit farther after the brake lights come on then stop. the lights go out. kinda like something is leaking vacuum or something. There is some adjustment in the peddle linkage and on the booster, maybe that is where your problems are. just a thought.
74bronc
You didn't mention what master cylinder you are running.
Also, what do you mean by "stock proportioning valve"? What year is your bronco. I am sure you know that a proportioning valve was not used until 1976 and 1977 model year EB's
Did you adjust the little pushrod coming out of the booster that fits into the end of the master? My JD booster has it and I suspect the BC booster has it too.
FYI, I converted using Chevy parts last October. I used 1974 Chevy spindles, brackets, calipers etc. Replacement rubber caliper lines, left the stock drum brake line distribution block in place rather than install a proportioning valve, I have a james duff power brake booster (already installed before the disc conversion) and a 1976 F-250 master cylinder. The brake pedal is solid and it stops great.
I suspect poorly adjusted rear brakes or master cylinder......but all we can do on an online message board is guess because we can't physically come over and look at it ourselves. :)
LSUpete
LSUpete
Okay, here's some more info.....
The booster setup from BC Broncos comes with the MC (1 1/8" bore) already attached. So, I believe that everything is already adjusted properly.
My Bronco is '75 model, but I installed a stock proportioning valve from a '76 model.
I suspect it is an issue with the MC, because the booster is working great.
Unless I get a definite answer from you guys, I'm going to install a new MC and a set of Russell speed-bleeders.....and see if that helps.8)
66horse
Let me know what you learn Pete. I have the same setup excpet for the proportioning valve. And i have the same issue.
And ya, the speed bleeders are sweet. If you dont already have them and if no one sells the Russels down there, Pep Boys and Autozone, Napa all sell the same thing in the HELP! section.
LSUpete
LSUpete
Will do buddy.
Hey, I just got back from the ranch in Costa Rica and have some info for you. I found a place downtown that has a "back room". For 6,000 colones you get to spend an hour in a room full of morally casual sweeties.....we had a blast!8)
72bronco
I just recently went through a disc brake conversion and power brake upgrade. As with most upgrades, I had to make a few adjustments to get everything to work correctly. There's a few things you can check. First, I had bled my brakes many times but was still having problems. Then somebody suggested that I remove the calipers when bleeding them the first time making sure that the bleeder valve was pointing straight up. Turns out I still had some air in there that my repeated bleeding wasn't getting. I also had a problem with the brakes not fully releasing after I press on the pedeal and I had to adjust the rod that comes out of the brake booster. There's a nut on the end of it that you can turn in or out with a socket wrench. I also had problems getting my brake lights to work properly but after adjusting the pedal height it seemed to fix itself. Perhaps the angle of the pedal assembly against the brake light switch wasn't correct.
77TexasBronc
Baytown Texas
I have had what sounds to be the same problem before. I would suggest adjusting the small push that is between the MC and the booster. Sorry but this is still a best guess.
lars
Been here awhile
NorCal flatlands
Pete-
I tend to agree with 74bronc...
1. Verify that the rear brakes are adjusted properly. If the shoes are sitting far from the drums, they can suck up a lot of pedal travel.
2. Verify that the booster pushrod is adjusted properly. The one that depresses the piston in the master cylinder. If the pushrod is too short, it could cause the problem you describe. DON'T use the length specification published in various shop manuals. The bore in piston of your master cylinder is deeper than the OEM piece, so it requires that the pushrod be adjusted out further. If you remove the two 9/16" nuts retaining the m/c to the booster, you should be able to pull the m/c away, assuming the hard lines from m/c to prop. valve have some slack in them. The goal is to have the pushrod adjusted so that it just (like a few thousanths of an inch) misses bottoming in the piston when at rest. I adjusted mine by purposely making it too long, then attempting to slide the m/c onto the booster studs, feeling for when the pushrod bottomed in the piston. Then estimating how far the m/c stood off from the booster. Then adjusting & repeating till I got it. Not very scientific, but it worked.
3. If you want more info, you'll have to tell me more about Costa Rica.
66horse
LSUpete said:
Will do buddy.
Sweet! thats like 15 bucks right?
I am trying to talk the wife in going down for christmas, but she is having some issue about christmas being for spending with family. I want to go find a place to buy! Actualy I found a cool place. Little more than I want to spend but seems cool. What part of the country is your place in again?
LSUpete
LSUpete
My place is on the Gulf coast, east of Rita.
