farzadmip
- Sep 11, 2009
- 613
So I've been struggling to do this junk yard conversion on a 71 d44. I've done the conversion on the 68 and used a larger backing plate that posed no problems. We'll when I fitted it all on the 71 all was well except the stock steel wheels wouldnt fit. So I went back to the junk yard and picked up the heavy duty backing plates that are the full circle ones. Fit inside the wheels no problem. Problem is the rotors are too close to the backing plate to get the back brake pad in. At first I thought it was because I was using the spacer method on original ford spindles. So back to the junk yard for chevy spindles. Bolt it all up and have the same problem. I called horses because theyre always awesome about tech and he informed me they use the 76-77 rotors from a bronco. I told napa 88 ford f150 rotors because I always read to use f150 rotors up to 895 as long as they weren't abs. Could the rotors be the problem? I did use the same rotors on the 68 but they were different backing plates. Any help would be appreciated this thing had been killing me for awhile. I keep moving on to other projects because I'm so frusterated. Ready to say screw it and rebuild the drums...
