Chevy tie rod ends Conversion
dgold_881
Has anyone done this on a 76 bronco? I'm looking at the one from Ballistic Fabrication. My question is what are the tie rod lengths needed for the front dana 44? Is it a standard size across the board for dana 44's ?
surveyor5
Oakridge, OR
I will measure mine and let you know. Understand this, I have a 72 front axle with 76 knuckles installed. I don't know if this is different or not. Back to you soon.
bigmuddy
Marthasville Missouri
Lots of people here running the chevy TRE. They will all be a bit different depending onthe knuckles being run. You might also check moabmike in the vendor forum for a reasonably priced kit.
Ben
dnewman9
I bought the ballistic kit. I would mock your links up to ensure you have adjustability and then weld. Copying anyone else's setup will likely lead to you doing it a second time.
Dennis
dgold_881
dgold_881
Thats just it I don't know how much play on each side of the TR that I need.
Do I just measure the total distance between the TR holes order that size then hack it down as needed to get enough adjustment play on either side?
Dennis
needabronco
Prescott/Farmington
Measure the distance from stud to stud on your OLD setup. Then measure the length of your new tie rod ends, you want about 1/4" of threads or a little less exposed. That should give you the length of tube you need.
dnewman9
I threaded on the jamb nut, with weldable bung and measured the distance between where the tie rods should be. I then tacked it together and made sure I could get my toe in right. Once that was done I finished welded the bungs. That is another whole process, weld 1/4 at a time opposite sides and let it cool so you do not weld through. There is a better write up on here somewhere.
Dennis
broncnaz
Keep in mind that you may run into wheel fitment issues with 76 knuckles and ch#vy TRE's. Most people have to run spacers unless they go to bigger wheels.
