City Bronco build - '68 Sport
ECEB
From your VIN plate I get:
-U150 wagon
-with 289
-color light blue
-july 68 build
-sold out of denver
that's going to be fun.
okie4570
NW OK
Glad you made home safely. Get a Marti, curious to see if it came from Rosen Novak Ford in Denver like mine did in 71'. :)
DC_Gearhead
DC_Gearhead
-U150 wagon
-with 289
-color light blue
-july 68 build
-sold out of denver
Thanks. That would explain the blue paint I have seen in seams and such. My wife loves the Caribbean Turquoise Broncos. If it were that color I would have been forced to paint it back to the CT. Thanks again for deciphering that.
DC_Gearhead
DC_Gearhead
I got my Marti report. Pretty cool info.
okie4570
NW OK
Different dealer than mine, will have to figure out where dealer 76J417 was :)
DC_Gearhead
DC_Gearhead
That info is so cool to have. I looked around some more on my truck and what I previously thought was primer gray is actually faded and oxidated Skyview Blue. The history is pretty cool. Looks like yours was all tricked out with extras! Little bigger tires, Etc.
DC_Gearhead
DC_Gearhead
I'm trying to figure out what suspension lift I have on the Bronco. It has a bunch of Duff parts on it and it looks taller than stock. Does someone have some dimensions I could check?
I attached a pic below. It looks like these blocks shouldn't be there. Obviously that wedge isn't supposed to be there.
hucklburry rev2
looking at your first pics, I'd say you need a bigger hammer and at least 2 more jack stands. Glad you get to keep that one in the family.
DC_Gearhead
DC_Gearhead
Dug into some small cracks in the drivers door and found some Bondo. Looks like they had a dent filled in, the Bondo cracked, water went in the crack and rusted the sheet metal. It's not bad, but it is something to address. I may just re-skin the doors since the skin is the only cancer I see. No rust inside the door at all. Kinda strange actually. I'm replacing the rear quarter so I'm not worried about the rust through there.
Heat gun and putty knife.
DC_Gearhead
DC_Gearhead
I did some work over the last couple weeks and figured out my Bronco has some hidden issues. I was lifting the body to install new mounts and noticed my rocker panel was moving. Did a little investigation and realized my plan to get the Bronco driving in the next month is unrealistic as hell freezing over. Up until now I figured hey, it was a daily driver for years. If I just get the engine going and other systems going again, I'll just drive it for the summer and do my metal work in the winter. Well....curious it's killed the cat.
I pulled off the driver side door weather stripping and saw that some of my Sheetmetal is pop riveted and siliconed together.....not welded. Floor pan to rocker panel? Pop rivets and bathroom silicone.
Then the subject of body mounts comes in....what body mounts. The only connection between the body and frame that was still operational was the body mount in the front floor boards. Both sides were bolted, but they were loose. The floor boards had been replaced and the just cut around the bolts. The bolts were sitting down in the channel under the new floorboards. Some of the frame holes for the mounts are too big as well because of rust or excessive wear so I'll need to reinforce those as well.
So long story short......I've put my delusion of getting it driving this summer in the trash.
Bottom line is I am replacing:
A Post driver side
Inner fenders both sides
Outer fenders both sides
Drivers front wheel well
Maybe radiator support
Front body mount brackets
Grill
Rear tailgate body mounts (hopefully not entire channel)
Both rear quarters
Passenger rocker
Driver/pass front floorboards
Windshield frame
All this on a Bronco that looked "pretty good".
I enjoy this kind of work so it will be an adventure for sure. Luckily the parts are relatively cheep and I live pretty close to a supplier (CJ Pony) so no shipping on sheetmetal. The talk with the wife about spending money is the only part I don't look forward to.....
Cleaned up a little and removed the rivets and silicone.
DC_Gearhead
DC_Gearhead
I started deconstructing the Bronco today. Other than broken bolts it ain't too hard breaking things down. I have a few new sheet metal parts coming this weekend.
I figure I will start up front and work my way back.
DC_Gearhead
DC_Gearhead
I haven't shared in a while, so I figured I'd give a little update. I've gotten a lot done so far and my goal is to be driving by this summer.
So far.
Power brakes
Disc brakes after I worked through some issues with the SSBC kit...
2.5" lift from Duff and all new bushings and Bilstein shocks
Power steering
Blasted and coated my manifolds
Installed kick panel, door post, floor board, inner rocker, outer rocker, and rear quarter on driver side.
New wheels and tires.
Painted and replaced seals in front end. Painted everything while I had it apart. I replaced seals on 9", transfer, and 30.
Working on my door skin now. First time doing it, but ordered an Astro 1000 skin tool. Figured it's worth the $130 for both doors. Ordered all the felts and tracks so I can install and align prior to skinning.
Moving along. I'll give another update sooner than 6 months.
JCBombardier
Wow great progress!!
What do you think of the Duff's 2.5" kit? Do they offer a kit with the Bilstein's or did you have to get it all separately?
DC_Gearhead
DC_Gearhead
I love anything Duff. They make great stuff. I bought the Bilsteins separate, but I hear the Duff shocks are great too.
Tiko433
South West Florida
Pretty work ! Your Uncle would proud. Keep us posted. Also check out B.O.A.R. ( Bronco Owners Association of Richmond. It's a strong club a little south of you.
