- Sep 26, 2013
- 2,397
Went to start the Bronco this am and only got the dreaded click of the start solenoid. Lights work. Battery checks at 12+ on the multimeter. Jumped the solenoid to check for voltage across the terminal and its there. Battery is grounded at the block and the core support. Block is grounded to the frame and continuity checks show good everywhere I tried. Truck has a mini starter that I have not checked yet due to the need to be at work. The odd part of this is when I was checking the solenoid I saw smoke on the right side by the brake booster. Checked for evidence of a short or burn but finding none, I tried the solenoid again and saw a spark and then a flame from the rag joint on the steering shaft-yes the rag joint. Obviously this will need some troubleshooting as there appears to be more than one issue here, but I figured I would throw it out there so I'm not the only one scratching my head.
