[quote author=vtdon link=board=5;threadid=11215;start=0#82988 date=1037362052]<br>Agree w/Rusty WRT cost vs return.<br>I addressed the liability of clutch fans previously. There is a damn good reason serious performance and race vehicles never use clutch fans. There is either a bushing or simple bearing to allow the fan to free wheel. With wear, there will be an increase in blade deflection.<br>I once put a clutch fan into the radiator as the result of a missed shift. No amount of fuel savings as a benefit of a clutch fan can ever out weigh that experience. <br>[/quote]<br><br>The reason serious performance and race vehicles do not use them is because they need constant cooling all the time as their engines are being worked very hard. <br><br>As far as bearing wear or Clutch lining wear all of our Clutches at BorgWarner carry a 500,000 mile warranty and many see over 1,000,000 miles before they need any maint. How many Broncos have seen over 200,000 miles? <br><br>"With wear, there will be an increase in blade deflection." How do you figure? The Clutch has nothing to do with blade deflection, it just spins or doesn't spin the fan. The fan will only deflect so far at a given input RPM and there is No RPM multiplier in the clutch so the fan will see the same RPM as if it were directly attached to the motor.<br><br>I am at a lose for your missed shift / clutch into your radiator. It sounds like you didn't have something installed correctly as this shouldn't be possible for just missing a shift.<br><br>I too Agree w/you and Rusty WRT cost vs return. No amount of fuel savings as a benefit of a clutch fan can ever out weigh that expense unless you put a whole lot of miles on your Bronco. <br>But then again for me the cost is just a little time in the R&D department fabing new shafts that will mount to the 351w.
