Clutch pedal push rod location
Nowik35
Does anyone have measurements or a template where and how big I should be drilling the hole in my floor for the clutch pedal push rod to connect to the equalizer bar? I only just noticed after paint that this hole didn't come predrilled and I don't have my old floor panel to remeasure. That being said I only have one shot and I don't want to screw it up.
EPB72
Pleasant Hill, CA
Mine I drilled 12 7/8 from left kick panel. 1 7/8 down from bent at firewall slant , and is 1 7/16 to left of the coulmn mount bracket lower bolt hole .. { the triangle bracket that mounts on engine side , the lower captured nut is what im refering to ,The hole is slightly larger 1 1/2 in diameter ,,,,, I did replace my floors an had the original piece that I marked up a saved for this reason ,,, Before i n this drilled I searched for measuments there are a few threads this , google seems to be a better way to search then classicbronco threads pop up,, where mine is its within a 1/4 inch of what past threads others measurments.. I will also say the original hole diameter on mine was 1 3/8 inch but the new rod boot fit better at 1 1/2 ......
