pipeline010
- Nov 15, 2017
- 618
So I ordered a new clutch push rod. This is the one that connects from the back of the clutch pedal down through the floor.
https://www.tomsbroncoparts.com/pro...d-wbushings-clips-66-77-early-ford-bronco-new
My mechanic was supposed to come and help me with the swap (and a few other odds/ends) but he had to back out. I figure I can handle this on my own.
Before I start, my assumption is I'm removing two cotter pins, pulling the old rod out through the boot in the floor and putting the new one on with new pins.
I'll need to depress the clutch spring down to re-attach the bottom of the new rod with the cotter pin.
And that's it right? This is just a not complex 20 minute (or so) process?
Anything I should expect?
Full disclosure: I can be a real moron.
Thanks.
Thanks.
