Hey Guys and Gals, I need some help with the install of my new BC 3.5" coils. I'm replacing my d30 with a d44, new bushings and shock mounts on my frame resto. Beside the fact that I have been battling the radius arms and the new bushings. I got to looking at the new coils and the diameter of the new coil is alot smaller then the old stock coils. I attached the coil spring cup to the top of the radius arm and set the coil on top of it but the lower coil spring retainer will not fit inside the coil. Is it suposed to be this tight. Should use the BFH on it or what? Has any one else had this problem with BC coils? Thanks for the help. 69sport
