cold duck question
Boss Hugg
JW posted pics of a cold duck in post #112 of Nyles' post here: http://classicbroncos.com/forums/showthread.php?t=170857&page=7
what's the purpose of the hose?
I guess because the thread is archived, I can't open the pics to get a better view...
I'm looking at redrilling a d20 to clock it just under the rear case, thus the rail would be on top and shouldn't leak.
AND DON'T TALK HERE ABOUT GOING 203 OR ATLAS OR STAK OR KLUNE OR...WHATEVER ELSE...
This is just a thought project resulting from a sick day on the couch. Crazy things go thru your mind when you're high on drugs with a fever.
englewoodcowboy
Lick Creek Restorations
From my understanding it was a old way to achieve an overdrive by adding another gear set or under drive depending how things were done. That method is not very efficient compared to proper gearing for your tires and an actual OD transmission etc.
Boss Hugg
Boss Hugg
I do see how you could make a 40 or 42% OD with it. You could do really deep axle ratios, but you'd wind up having to split 3 & 4 to keep From having a huge jump from 4th OD, if you know what I'm saying. Like a two speed axle in a big truck.
It's been a long time since the Cold Duck got analyzed. But if I remember correctly the shift rail is now at the bottom. The shift rail cap that normally only has to deal with air is now acting like a (poorly made) hydraulic cylinder. I believe that is simply a vent to allow the back of the shift rail to move without being hydraulically jammed.
Boss Hugg
Boss Hugg
Bowsher, I would be clocking it to the drivers side so the rail is still on top.
Sent from my iPad using Tapatalk
WILDHORSES
USA
BINGO!
The later versions had machined shift rail to eliminate the hose.
Jim
JWMcCrary
I have 2 of those, one with the hose and one without. Running the one without the hose in my green 73. Have to change the shift rail seal every couple years but it's easy to do.
gddyap
Mtn View, CA
I got one of the last ones from WH. Mine has a vent hose that goes up to a catch can. The shift rail leaks a little oil. It wasn't meant to be submerged in oil.
JWMcCrary
The one I'm running now has that vent and I made a catch can out of plastic pipe and have it on the passenger inner fender. Only time it pushes any oil into it when you drive on the hwy.
