77RHINO
- Feb 22, 2011
- 308
My bronco not starting this morning really sucked, so this is part ranting/part questioning about old school tech that I am still learning about. I don't have anyone to discuss these issues with, so ya'll gotta bear with me!
Backstory: I finished my first engine build back in March, and within the first few drives it destroyed the rear wheel bearings, and had to park it until I could save up enough for a rear end rebuild w/ new gears, upgrading from 3.50s to 4.56s. Now that I get to drive it more consistently, I am noticing some different handling issues and quirks with the rear-end being all nice and tight.
Starting: When the engine is cold, it is a pain to get going, usually 3-4 times trying before it hesitantly coughs to life, which is a complete 180 from how it'll start if I have cranked it that day. When hot, it'll fire up within 1-2 secs of the turn of the key, and it sounds good. I know I still have some choke adjustment, but with the weather changing like it is (30 something last weekend, 75 this coming weekend) I cant seem to find a happy spot.
Once I do get it to cold crank, I have to immediately get it out of the garage, because it blows black wet soot out of the exhaust pipes for the first few minutes, which my local mechanic said was probably just unburnt ethanol? When it is warmed up, it drives good half the time. I have times that it will absolutely scat down the road, and others that it will surge and sputter, not wanting to pick up and run like it should. I've never tried flooring it, and I haven't found a common hill/grade or a certain throttle position that causes this, which makes me wonder if it is just dumping too much fuel that its not getting it all burnt? I am going to buy a jet kit from Edelbrock, I have a 650 and wonder if maybe the primaries are too big? A couple weeks ago it did run-on just a couple weak times before turning off, which is the first time it has done that since I swapped to premium fuel. It had also surged that day as well, where I was getting up onto a highway and it just didn't want to accelerate. When I took it to the shop for the rear end, I asked about the timing and how it started for him and he said it started great all day, which means it never cooled off enough for him to witness my cold start issues.
New Leaks
Now that I have gone through a few heat cycles, I am noticing some leaks on the floor: Head gasket at rear driver side, master cylinder/booster started leaking (maybe caused by new vacuum levels of new engine?) the master is only 5 years old. Front main seal and power steering low pressure return line. I hope re-torquing the heads will help, as my oil looks great and my spark plug at #8 near that leak looked nice and tan. I can't tell if the spot on the floor is coolant or brake fluid anymore, as they both land in the same area and get blown around by the fan while running. I have added a whole bottle of brake fluid, and only about 1.5 inches coolant, which is only distilled water at the moment. I will be flushing the water and replacing with coolant once I believe everything is good and set, but I have probably only put 4-500 miles on this motor since the install.
Driving: Noticed at certain speeds (once around 50 and once around 70) that I will get a heavy vibration like its lost a wheel weight, and this has started with the new gearset/rear rebuild. I don't know if the rear end had so much slack in it before that it ate up the driveline vibration, or if something else is going on, like maybe flat spots in the tires from sitting, even though it usually doesn't sit more than 3 weeks without a drive. The vibration gets rhythmic, but if I give more or less throttle it will go away and I can cruise normally. I originally thought this was buffeting because I was running the bikini top with no windshield support, but it does it with my hard top on as well.
Engine Stats:
Block – 1996 Hyd. Roller bored .030”
Pistons – 6.50+ flat top w/ valve reliefs (hypereutectic)
Heads – FR GT40X Aluminum 64cc chamber, 178cc intake runners
Headers - WH long tubes
Valves – 1.94 Intake, 1.54 Exhaust
Carb – Edelbrock AVS 650 CFM Elec. Choke
Cam – Comp XE 266HR-12
Distributor – ’78 cap and rotor, ‘77 funnel, ’83 shaft/pickup, ’96 cam gear
Head Gaskets – Fel Pro 9333PT1 0.047” THK (mis-quoted this in another thread)
Wires – Ford Racing 9mm
Coil – Factory replacement
Ignition – Factory Duraspark module
Intake – Edelbrock Performer
Rockers – Scorpion Roller Rockers 1.6 ratio (pedestal mount)
Lifters – Factory FR hydraulic
Pushrods – factory length/hardened
Harmonic Balancer – Summit Racing 28 oz.
Flywheel – 351w 28oz.
Timing at idle is about 7-8*
I am nervous with setting my timing, I don't want to burn pistons or bend pushrods (is it an interference engine?) I'd like it to be in a good safe and reliable spot for all around driving.
Mated to nv3550, Suspension is WH 2.5 w/11-leafs and bilsteins, extended WH driveshaft, BFG MT 33s. No sway bars or axle-wrap bars
I need to buy a vac gauge, comp tester, what else for diagnostics?
Sorry for the long winded rant and scattered questioning, I'm hoping a few of you know some simple and cheap tips to solve these issues!
Thank you,
Ryan
New Leaks
Engine Stats:
Thank you,
Ryan
